Hi I got an 00 banshee with the following descriptions below. I recently installed some fatties and v force reeds. Now it bogs out through most of the powerband and has a slow throttle response. Rides slower than stock banshee in straight aways, and totally bogs out going up a hill or dune. I tried new fuel, spark plugs, cleaned filters, cleaned carbs and jets, tried swapping reeds with a friend, recectly rebuilt, tried 260-310 jets(currently at 260's), all needle positions(currently at 2nd to bottom), adjusting air screw, elevation around 300ft. So what else could it be ? Thanx banghead
You might have forgotten the choke tube between the carbs, put the slides in the opposite carbs so they are backwards. (cutaway should face the air box) or your tors might be malfunctioning. If so, then disconnect the little black box above the left exhaust (3-wire plug) and disconnect the parking brake switch. Let us know how you make out. Its not your jetting from what your telling me...
