this has got me puzzled. I have changed coil (under gas tank),cdi box, tried to disconnect TORS and still does not run anyone know where to look is it stator. I have 2000 shee
do you have spark to the plugs?.....pull the plugs ground them(eng case etc) kick it over look for spark
if you cant see a spark hold onto the electrode of the plug and it will magically send a signal to your brain that, yes there is spark. :evil:
also before it quit running it would idle on 2 cylinders hit the throttle and it sounded like it was hitting on 1 then it would die if this helps for diagnosis
that is what I was hoping cause my brother comes back with both his shees in a couple weeks. So by replacing stator hopefully it will be fixed anyone have one they would sell.
