ybanshee203 Posted July 21, 2004 Report Posted July 21, 2004 I have a few questions I need answered. First, when you install a aftermarket set of clutch plates do you use the cushions that are used in the factory clutch? Second, if so how many are there? The Banshee Manual says to install a cushion against the back of the clutch basket then install a friction plate, followed by a clutch plate, then it says repeat. Does this mean to install a cushion between each clutch and friction plate? The deal is that my friend smoked his clutch out and when I took it apart there was only two cushions, one against the clutch basket and one against the pressure plate. The reason I think there could be more is because there was a lot of clutch material in the bottom of the clutch cover. Any help would be greatly appreciated. Quote
frocashmoney24 Posted July 21, 2004 Report Posted July 21, 2004 on any aftermarket clutches, throw away the orings, they do nothing Quote
QuadMX Posted July 21, 2004 Report Posted July 21, 2004 on any aftermarket clutches, throw away the orings, they do nothing What he said. Quote
ybanshee203 Posted July 21, 2004 Author Report Posted July 21, 2004 Thanks a lot for your help. Quote
