so i start the banshee the other day, and it idles fine and warms up, then i go to ride it down my street, but it has no power at all, im talking full throtle i was only going 5 mph max it sounds like its boging, but the motor doesnt die and everything shakes. what could be wrong? changed the plugs the slides move together. just has no power
Will it rev up cleanly while it is sitting there idling, or does it not rev?
If it doesn't rev up, but bogs when you try to, your emergency brake switch
or wiring may be bad. On the handlebars (clutch side), there is a black
jacketed wire that goes to your emergency brake switch. Trace that wire
down to the first connector (down in front of the radiator I believe) and
disconnect it and see if that helps.
You beat me too it Banshee04, I would say its the emergencey brake switch as well. Unplug that and your TORS and you should be good to go.
