factoryshee Posted July 15, 2004 Report Posted July 15, 2004 ok so i have no idea wut the hell is wrong with my baby she doesnt seem to want to start worth of shit and it backfires like crazy when i kick it- the other day i finally got it running and it would idle fine but then if i got on it she would bogg reall bad then rev the bogg and so on can any one please help me possibly tell me wut to check i dont think it is electrical cuz it still has spark-sorry for such a long thread Thanks PlUmP Quote
frocashmoney24 Posted July 15, 2004 Report Posted July 15, 2004 how does the plugslook? it sounds like you have a combo problem, of lean running, and maybe a stator going bad Quote
ledofthezep Posted July 15, 2004 Report Posted July 15, 2004 Yepper, sounds like a sever air leak, hosed reeds, or stator. Quote
mrmatt Posted July 15, 2004 Report Posted July 15, 2004 Your flywheel key could be sheared. Did you recently install a degree key? Quote
factoryshee Posted July 16, 2004 Author Report Posted July 16, 2004 (edited) no degree key but i intalled an adjustable timing plate but its still set to 0 and its got a brand new cdi on it um where could i have an air leak everything is new reeds are brand new too so i dont know wuts going on shits all bad plugs are fine it fires but dies right away please help i think water might have gotten in somewhere cuz it was in the rain is that a posibility or could i adjust the timing to like +4 maybe that would help? Thanks again PlUmP Edited July 16, 2004 by factoryshee Quote
frocashmoney24 Posted July 16, 2004 Report Posted July 16, 2004 advancing the timing wont do anything. the plugs dont look lean at all or rich?, you sure the stators a good one? Quote
factoryshee Posted July 16, 2004 Author Report Posted July 16, 2004 that stator was fine the when i checked it out after i took the plugs out they were burnt to shit but it ran fine one day then the next day it wouldnt run PlUmP Quote
bansheefreak Posted July 16, 2004 Report Posted July 16, 2004 (edited) you might check the wires going to your plug wires .. they are right there by the right side pipe up under the tank... my brother's banshee was backfiring and bogging real bad and we found that one female connecter was lose so it was arching and not getting spark right even thou we would pull the plug and have spark...we fixed the female end and runs like a champ now.. Edited July 16, 2004 by bansheefreak Quote
factoryshee Posted July 16, 2004 Author Report Posted July 16, 2004 iight thanks bro il try that in the morning-can any one tell me how i can put a picture above my name like banshee freak has? PlUmP Quote
ledofthezep Posted July 16, 2004 Report Posted July 16, 2004 You have to go to your "My Controls" & submit an image for an avatar. where could i have an air leak Fire it up & spray some carb cleaner or WD40 around your intake boots & see if shee revs. Quote
2banshees Posted July 19, 2004 Report Posted July 19, 2004 theres one more thing that no one has mentioned.check the orange wire that runs to your coil. may have a rub hole in it and groundingt out. Quote
sredish Posted July 19, 2004 Report Posted July 19, 2004 You have to go to your "My Controls" & submit an image for an avatar. where could i have an air leak Fire it up & spray some carb cleaner or WD40 around your intake boots & see if shee revs. i agree with led's approach. sounds like a lean condition caused by an air leak. get some wd40, carb cleaner and spray away. hopefully you'll find something. Quote
factoryshee Posted July 19, 2004 Author Report Posted July 19, 2004 i guess ill try all of the approaches and see whats happens thanks for all the tips guys PlUmP Quote
factoryshee Posted July 19, 2004 Author Report Posted July 19, 2004 ok none of these approaches are working and im getting fed up with all this bull shit i dont think it has nething to do with the stador or anything that has to do wit the ignition system becaus eit has a perdy blue spark consistantyl other than buying new intake boots idk wut else to do please help me guys Thanks PlUmP Quote
factoryshee Posted July 20, 2004 Author Report Posted July 20, 2004 ok i think i solved the problem rotten fuel? could this be the problem? PlUmP Quote
