frocashmoney24 Posted July 7, 2004 Report Posted July 7, 2004 (edited) well i just did a test after runnin with a few diffrent settings, what should i do from here? ok what the shit, now we cant post from freepichosting either? Edited July 7, 2004 by frocashmoney24 Quote
svtkid78 Posted July 8, 2004 Report Posted July 8, 2004 They look pretty good, maybe a little little bit lean. Looks like its runnin pretty good though. Wish I could get mone looking like that. Quote
banshee04le Posted July 8, 2004 Report Posted July 8, 2004 How much time you got on those plugs. You didn't get that much coloration starting with new plugs and doing a wot chop test. On a wot chop test, the plugs will look very lean to someone who is used to reading plug color on 4cycle engines. On a properly performed throttle chop test for jetting purposes the only coloration you are looking for will be a ring that should form on the most recessed part of the center electrode insulator. The whole insulator will not color...it will look lean to someone who does not know to look for the ring. Those plugs do look ok though, for being in sevice for a short time. Quote
sredish Posted July 8, 2004 Report Posted July 8, 2004 (edited) For the most part, I like them. I'd put them back in and get them some run time, get them hot and wet. Ride for a little while and hit your WOT run again just to double check, but it looks like you've gotten her pretty darned close. Only thing I see is in your top picture, looks like the color changes a little towards the center of the electrode, you really want it more towards the middle of the bend, which for your case would require it to be a tad richer. Just giving you exactly what I see, for you to do with what you want. Not bad at all though, I like the overall coloring. Edited July 8, 2004 by sredish Quote
