eehsnab2 Posted June 21, 2004 Report Posted June 21, 2004 I bought some used Kehien's and have them in sync but I'm not sure how to set the idle. Anyone able to help me out? Quote
eehsnab2 Posted June 21, 2004 Author Report Posted June 21, 2004 same ones that you pull??? Is it really that easy? Just the knobs right, not at the base? Do you need to screw them all the way in and then work out? Quote
tats4life Posted June 21, 2004 Report Posted June 21, 2004 not the ones you pull, turn the base nut lookin thing. Quote
eehsnab2 Posted June 21, 2004 Author Report Posted June 21, 2004 how does the choke assembly not rattle loose then? Quote
Brian G Posted June 21, 2004 Report Posted June 21, 2004 no, just turn the knobs!!!! do not touch the base nut, they will not rattle loose, they have inner channels you will feel them go into the notches a quarter turn at a time. Quote
Schizo Posted June 21, 2004 Report Posted June 21, 2004 Yes just turn the black choke knobs counter clockwise for higher idle and pull straight up for choke..... Quote
tats4life Posted June 22, 2004 Report Posted June 22, 2004 not the ones you pull, turn the base nut lookin thing. sorry my head was not attached this morning, yes turn the choke pull not the base nut. Quote
