BansheeBoy17 Posted June 21, 2004 Report Posted June 21, 2004 Ok Im still deciding whether or not to get this 4mm stroker crank thats on ebay.... what all will I need in order to run this type of crank ?!? Plz hurry theres 4 hours left Quote
23champ Posted June 21, 2004 Report Posted June 21, 2004 When you stroke a motor it throws all your port timing off so you will either need to have someone change your port timing by porting the cylinders ,or buy a spacer plate, or both depending on wether or not its a "longrod" stroker crank or just a stroker. if its a longrod stroker you're best bet is to use wiseco's 795 pistons(they relocate the position of the wristpin). for more info.call Jim at passion racing he'll hook you up with a sweet motor 918 232 3950 Quote
