jetting
Yeah, could be. Could be lean also. We really can't tell you, only thing we can tell you is if your close or not, and your probably pretty close. The jets your running should be enough to get you a decent reading on the plugs. The ONLY way to know for sure what the proper jetting is is through a plug check.
Read BenBB's Jetting FAQ for more info on checking plugs and jetting. Then adjust the needle up or down for response and most power.
ok, would going up on the needle richen it or going down?
this can sometimes be confusing, so let me try to see if i get it out right.
raising the needle/lowering the clip will richen.
lowering the needle/raising the clip will lean.
typically, we refer to the clip when discussing needle adjustments, because it's easier and we don't confuse each other. so, stock is 3rd clip from the top/blunt end. to richen one, go to the 4th clip from the top/blunt end. also, it doesn't hurt to play with the clip settings. richen it one and see how it feels. if you like it go one more. if you get to a point that it gets worse, lean it back one and you know where shee likes it.
hope that makes sense? let us know if you have any more questions.
