I am thinking of buying a set of T rex cylinders and Was wondering who ports
them? Is it more expensive then stock cylinders? Wheres the bests place to go? I
was just thinkig a play, mx port job. <_< am I going to see huge gains or is it
better just to live the cylinders the way they come?
For a play/mx port job it shouldnt cost that much more than it would for stock cylinders and yes you would see an increase in power.Right out of the box they put out about 60hp,with a play/mx port "around" 70hp it depends alot on the builder's definition of a play/mx port...
For what you are looking for i would seriously consider the Cheetah cylinders option,they will produce about the same power as the ported T-REX cylinders would, maybe even a little more for less $$$.
Edited by Meat_Head
