banshee is still up for sale , parts but motor must go 1st or trade. if u want to trade tell me what u got and maybe we can work out a deal. plus i have other things i am selling that can go right now.
i am parting out this banshee if u see anyhting u want let me know but the motor must go b4 the rest of the quad. this motor was built by A&S banshee (dan hull) he dynoed this motr at 86hp in his shop running on 110 oct race gas. the motor has over $2000 into it. if u have any more ???? post in here or pm me
banshee motor that was built by Dan Hull at A&S banshee racing.this motor has a ton of work done to it. the motor is 20 over with a&s banshee modded wiseco pistons to match the port sizes and have been lightened. it has a duncan racing power head with 19cc domes cut down to 14cc domes. the motor has been ported and polished for drag. it is a level 6 port job welding & reshaping of transfers.Cut & Rechamber head. port matched cases. hinson clutch basket and barntte clutch. it has a hot rods trued and welded crank. it has shift star mod. v force reeds. pro design water pump impeller and pro desigh ez drain plate. it has a case saver to keep the chain from breaking the case. white brothers boost bottle and stock intakes. ricky stator high output stator and timming plate that gots from -10 to +10. the trans has been serviced and all seals have been change and the motor is still running great. this motor was made to run on race gas, alky or meth. only. this bike was dynoed at 86 hp running on 110 octane fuel. i ran motul 2 cycle oil at 32:1and motul trans oil. the is prob somethings i am forgetting. the pipes i have are brand new toomey tr6's with 0 rides on them. i was use 28mm pwk carbs.
  • 3 weeks later...
