can u replace the oil seal under the clutch push lever without spliting cases? Been a few years since i've worked on this banshee(this is a good thing). Please tell me this is an easy job, I'm getting too old and impatient to work on this. lol tx for any help
You can change the seal without splitting the cases, but you will need to pull the side cover off so that you can remove the clutch pressure plate and pull the rod an ball.
tx blacksmith. once clutch is removed then the push lever will slide right out of the top, and the oil seal can be pulled out then? anything tricky? I put new toomey clutch on (couple years ago) found the ball on floor after it was all back together lol.
