ssbanshee Posted May 26, 2004 Report Posted May 26, 2004 when i shift it bogs for a sec then hits the band got any ideas Quote
sredish Posted May 26, 2004 Report Posted May 26, 2004 are you shifting too early in the powerband, try holding the gear a little longer before shifting. If your sure it's not that, is it at full throttle, 1/2 throttle? Quote
ssbanshee Posted May 26, 2004 Author Report Posted May 26, 2004 its not that, i went from 340 main to a 360 main do you think it is to rich 340 we lean and it poped. Quote
sredish Posted May 26, 2004 Report Posted May 26, 2004 sounds like your still running lean. what are your mods and elevation? If you ain't got much more than pipes and light porting, I'd begin to wonder if you don't have something else going on. Did this just start one day, or after some mods or what? Quote
ssbanshee Posted May 26, 2004 Author Report Posted May 26, 2004 (edited) ya i wan running 340s switched to a 360s and then it bogged down after i shited the 340s would not bog just pop a studder. is it just getting a little better but still lean? Edited May 26, 2004 by ssbanshee Quote
Banchetta Posted May 27, 2004 Report Posted May 27, 2004 Try raising your needles...makes a big difference on that hesitation before powerband.. Quote
