2004LEBanshee Posted May 26, 2004 Report Posted May 26, 2004 If I buy these reeds do I need to buy anything else to properly install them? Such as gasket's. And are the instructions pretty explainitory? Also I'm at 340's, stock pilots, and 4th notch should I expect any jetting changes and where? Thanks, Jason Quote
die_infidel Posted May 26, 2004 Report Posted May 26, 2004 Mine came with the reed gaskets and directions. Also says no jetting changes nessesary if you just put those in with no other changes. I would still keep on eye on your jetting just to be safe. Quote
baddboyy21 Posted May 27, 2004 Report Posted May 27, 2004 You may have to go 1 notch leaner on the needle. This means moving the clip up one notch. I have the Delta 2's and went 1 leaner and it is right on. Quote
sandman121383 Posted May 27, 2004 Report Posted May 27, 2004 i have them and i could notice the throttle response with them. not sure on ur jetting question tho. i never had any problems Quote
