banshee76179 Posted May 23, 2004 Report Posted May 23, 2004 I should be getting my new clutch in this week... Anything special I should know, or is it pretty much easy... Quote
Screamin_Banshee Posted May 23, 2004 Report Posted May 23, 2004 Follow the instructions it came with. Dont forget to soak the new fibers. Also, u order new springs with it? If so, alot of ppl suggest using 3 stiff ones, and 3 stockers...makes it easier to pull after long rides (less arm fatigue) Quote
sredish Posted May 24, 2004 Report Posted May 24, 2004 Follow the instructions it came with. Dont forget to soak the new fibers. Also, u order new springs with it? If so, alot of ppl suggest using 3 stiff ones, and 3 stockers...makes it easier to pull after long rides (less arm fatigue) There you have it. It's pretty freaking easy. Which clutch did you go with? Let us know how you like it afterwards. Scott Quote
