i have a 95 shee, stock except for v force reeds and no lid on the airbox (uni) filter. well it is not gettting the right mixture, so i took the carbs off to see if they were dirty...etc. the main jet in there was a 190, and from a search that seems way low. i couldnt find my exact setup so couldnt verify. i live at about 5000 ft elev, and the weather is about 70-80 degrees. thanks for any help
brad
First thing to know about jetting, is there is no absolute. Every motor jets a little different. While one person might be lean with 190, another could be rich.
Run a plug check and see how your plugs look, then decide if your jetted correctly.
BenBB's jetting page is a good place to start and learn how to run a plug check and read the plugs.
Later,
Scott
