jeepman380 Posted May 20, 2004 Report Posted May 20, 2004 I bought a pair of YFZ450 shocks and i've gotten all the grinding done on the mounts but I can't seem to get them into the bottom mounts. I can slide them up under the a-arms and into the top mount but I can't get the bottom of the shocks to clear the bottom a-arm. I don't want to have to unbolt my bottom a-arm but that looks like my only choice. Anyone have any suggestions? Any would be great. Thanks Quote
erbilabuc Posted May 20, 2004 Report Posted May 20, 2004 jack the front end as far up as you can so the arms extend as far down as possible, it will do the trick. Quote
jeepman380 Posted May 20, 2004 Author Report Posted May 20, 2004 Did that still won't work. Bottom still won't clear, keeps getting hung up. Quote
Dark Ranger Posted May 20, 2004 Report Posted May 20, 2004 Have you tried using a spring compressor to shorten it? Quote
bbluebanshee Posted May 20, 2004 Report Posted May 20, 2004 Did you do some grinding on the shock itself? I know when i put mine on, i had to grind about1/4 to 1/3 of an inch off the bottom of the shock to get them to fit. Quote
erbilabuc Posted May 20, 2004 Report Posted May 20, 2004 man play with it some more, when I did mine it went straight in, didnt have to do all this extra curricular shit except grind the upper mount Quote
jeepman380 Posted May 20, 2004 Author Report Posted May 20, 2004 I've done all the grinding to the shock mounts and to the bottom of the shock and I have it jacked all the way up and the a-arms are free moving and I got the top of the shock mounted but the bottom is like 2 inches away from the mount and won't budge. It needs compressed but I don't have any tools or anything to do that. What does anyone suggest? Quote
McSkinner Posted May 20, 2004 Report Posted May 20, 2004 Try putting the bottom in first. then push down on the resivoir to compress the shock enough for the top mount to slide in. Quote
jeepman380 Posted May 20, 2004 Author Report Posted May 20, 2004 Tried that...all I got out of that was a sliced in the top of my hand. Quote
ikikazz Posted May 20, 2004 Report Posted May 20, 2004 did you losen the spring all the way to the top if you did that then get a punch and place it in the bottom mount and tap it with a hammer to get the bottom to fit that is what i had to do. hope that helps mike Quote
