brock_fuzzy_69 Posted May 8, 2004 Report Posted May 8, 2004 well a friend of mine went to the dealership to look at a new predator and compare it to a Y 450 that steering setup on the pred is pretty slick the way it almost eliminates bumpsteer so can a setup similar to that be put on a shee i guess you coudl make a plate steel box to mount the idler arms inside of and modify an old bent steering shaft and then shorten your tie rods if u havent seen how the polaris is setup then this will all sound greek to you but if u have seen one then u will know what i mean Quote
