8HONDO Posted May 4, 2004 Report Posted May 4, 2004 can some one explain the difference in pistons to me and why you get a performance gain out of some but not others. what is the best kit to get for a semi built motor? Quote
Banchetta Posted May 5, 2004 Report Posted May 5, 2004 can some one explain the difference in pistons to me and why you get a performance gain out of some but not others. what is the best kit to get for a semi built motor? Cast pistons will heat up and expand at the same rate as you cylinders giving you better piston and ring life. Forge pistons heat up faster than the cylinders, so slow warm ups are a must. Forged pistons are supposed to be stronger. Some piston kits will give more hp due to wrist pin located lower on the piston causing the piston to move up higher making more compression which in turn makes more hp...Also changes port timing a little for higher revs, less low end..... Quote
8HONDO Posted May 7, 2004 Author Report Posted May 7, 2004 i was told not to run cast pistons on a moddes motor? Quote
