hello everyone. here is my problem..my sisters boyfriend smoked my clutch..welded the pushrod to the ball etc..I got the clutch shaft out but the pushrod dont want to come out>I dont know if I should try a rip it out or not is it possible for it to be welded to the other side? anysuggestion on how to fix? ive got all the new parts to fix it but I really didnt want to split the cases if I didnt have too..anyways any info would help out
Well, It could have managed to get snagged on the actuator. try getting a good hold of it and squeeze the clutch in and out...it should come free..if it don't, rip that bitch out by any means possible..there isn't much to damage if you have already pulled the clutch itself off and your left with the rod stuck inside the hole...you'll need to pull out your actuator and make shure that's good as well.
yea the only thing i got off so far is the cutch shaft..i havent took the clutch plates off...can i get to the actuator with out spliting the cases..i reayy dont know much about the clutch...
