bansheefreak Posted April 20, 2004 Report Posted April 20, 2004 for some reason my banshee runs perfect most of the time but when i get in tight trails and shee starts getting hot it will foul plugs one right after the other... is the common or what could it be ... i'm in the process of getting a propellar to help with the getting hott....so i guess what i'm asking is when motor is overheating will that make it foul plugs easier???? due to detonation??? Quote
sredish Posted April 20, 2004 Report Posted April 20, 2004 (edited) sounds like jetting. when your in the open your using 3/4 to WOT and when you get in the tighter stuff you use 1/4 to 3/4 throttle, which is a different circuit. If your fouling plugs in that circuit, you might lean the needle by moving one clip up towards the top/blunt end. Also get some Engine Ice if you don't already have it. It will reduce your temps 40 or 50 degrees. If you get in there, let us know what your settings, jet sizes and mods are and we can compare to others. Edited April 20, 2004 by sredish Quote
