akpopeye Posted April 19, 2004 Report Posted April 19, 2004 More rz stuff: Rz350 cases forsale, no damage, comes with shift forks/drum/star, bolts, kickstarter gear, mechanical tach gear, radiator hose. I also got a exteranlly mounted, independent tachometer to go along with the tachometer gears in the cases, all you will need is a tachometer cable (10 bucks) to set up the tach.... Rz350 cases, unlike banshee cases have the built in tachometer gears. The shift forks are better than banshees, they allow for smoother shifting. Buy these and replace the Banshee's cases, and then sell yours for couple hundred. I also got more rz forks and shift stuff forsale too! Quote
akpopeye Posted April 20, 2004 Author Report Posted April 20, 2004 Still got the cases, and two sets of rz shift forks with drum/stars.....these are rare, so buy them while you can Quote
NYUK Posted April 20, 2004 Report Posted April 20, 2004 ak,whatchu want for the rz forks?i gots lots o chrome.and another whole bike.in pieces.lemme know what you want for both sets of forks. Quote
akpopeye Posted April 21, 2004 Author Report Posted April 21, 2004 Still got two sets of rz shift forks/drums/stars/rails... rz350 cases/tach Quote
