How many main jet sizes will I need to move up with adding a Dyna Ignition. I currently run 300-310 mains and 27.5 pilots depending on the weather. I am at about 1250 ASL with SST pipes, Noss head with 19cc, K&N and V Force 2 reeds.
Shouldn't have to change anything. Your not changing the airflow or anything else that would affect the air/fuel mixture. Your just affecting how and when it sparks. Just check your plugs after the install to verify whether or not a change is actually needed.
I did go up on the main when I switched to a hotter sparking plug, so just check the plugs, these bikes all run a little different.
Edited by sredish
