thecabinboy Posted April 8, 2004 Report Posted April 8, 2004 Some little stuff rattling in there is the bad? Quote
frocashmoney24 Posted April 8, 2004 Report Posted April 8, 2004 yea man thats bad, hope its not ur degree key but i dont know how that would get out, pop off the cover n see what u got, just dont want it get jam the flywheel or get stuck to it and throw it off balance Quote
dnhyoung Posted April 8, 2004 Report Posted April 8, 2004 Some little stuff rattling in there is the bad? Better check it, When I had a little rattle in mine, It had come loose. Luckily it didn't mess up anything or I would of been pissed off. Lesson Learned. Double check that you torqued everything!!!!! Quote
boonman Posted April 8, 2004 Report Posted April 8, 2004 Pull the flywheel off. have a look see. Check the stator to be sure it's tight. Check everything over. Put it back together, and see what you got..... Quote
thecabinboy Posted April 8, 2004 Author Report Posted April 8, 2004 the rattle is on the flywheel itself. Quote
boonman Posted April 8, 2004 Report Posted April 8, 2004 When you grab hold of the flywheel, does it have slop? It could have come loose. The rivets could have come loose, but I doubt that very much. I am thinking that something is loose under the flywheel..... Quote
ledofthezep Posted April 8, 2004 Report Posted April 8, 2004 Your pickup coil isn't hitting the pickups on the flywheel is it? Quote
boonman Posted April 8, 2004 Report Posted April 8, 2004 God I hope not Led!!!! For the sake of ALL Shee owners... Quote
ledofthezep Posted April 8, 2004 Report Posted April 8, 2004 Me too....after I got in a hurry & installed my new stator I neglected to remember to adjust it. So when I got it back together & kicked it once, all there was was a rattle on the left side. I though, "that's no good" & pulled it all back apart, sure as chit, GD pickup coil was 'rattling' on the flywheel pickups. Luckily it only grazed it, no damage done at all...probably a good thing I didn't kick the crap out of it though! That woulda sucked. Just goes to show that it pays off to take your time & double check overthings before you try them the 1st time. Quote
