Hey yall! I am about to get my motor ported here shortly and I also want to get a +4mm LR stroker crank too. My question is, what all is needed to install a stroker crank like this and what type of power gains are expected with/without a port job? Is there a noticeable difference in power? What gives more power, +4mm or +4mm LR? Is overheating and reliablity an issue when installing one of these? Thanks for your time. Any feedback would be greatly appreciated.
Who is doing the work you should ask them these questions, talk to passions or grand river racing they should be able to answer all youre questions there is a couple of reviews on passion motors in the review section for a 4 mill do a search or call one of the shops mentioned,
your gona have to have some kind of porting to use a 4mm crank
as far as long rod or not go with the long rod it help the pisiton angle witch will reduce wear on the pistion skirt over heating and life of the engine in not a problem from what i have seen theses are really strong motors with torque up the ass
