8HONDO Posted April 1, 2004 Report Posted April 1, 2004 does anyone have pictures of where you need to hold the head when you are machining it? Quote
vmaxup Posted April 1, 2004 Report Posted April 1, 2004 you can use a kurt syle machining vise but not very stable. Or I built a little fixture to run bolts thru th spark plug holes to a flat plate and then hold the plate in the vise. run a stone over spark plug openings before attaching to the plate. I have also spun mine on a cnc lathe to do the domes and new squesh. I made a plug with spark plug thread mounted in lathe Did each bore seperatly Quote
