I have a set of .80 super stock pistons for a banshee they were only used 1 weekend and look great if interested make an offer they are like brand new there isn't even any scratches in the sides of the pistons.
you can use these pistons on a stock cylinder you just need to have them bored to .80 over this makes the 347 a 370cc. The only reason i took them ou t is because i had Jim (passionre) & passion racing engines do a full drag port on my bike and i could not run these pistons as they are relief cut from vito's to raise the exhaust port without porting the cylinder thes piston work great on a bike with a mild port job or even a bike with no port job as they make the motor react like it is ported. Check out vito's website for the exact specs.
