I think you can just unplug the cable.
Actually, unplugging the key switch won't let it fire. You can just tie all four wires together to complete the circuit since two of the wires aren't used anyway.
I think but not 100 % shure, if bike was left on and you unplug the cable it should fire up. But it would be better to tie em up, then you can clean up some clutter.
If you still want some security but don't wanna mess with a key then you can pick up a switch at any automotive place for a few bucks. Splice that in and zip tie it somewhere easy to reach, but not easy to find. I've got this setup and feel a whole lot better about leaving my shee out.
If you undo the plug in the harness that connects the switch you will see that there are two wires that connect the plug to the harness. Use as short section of solid core wire to jumper the two pins in the harness plug in. This will allow the bike to start. Don't worry about the 4 wires in the switch assy. Only two of them are used anyway.
