brugal Posted February 28, 2004 Report Posted February 28, 2004 Im going to naples on sunday,and cant have my shee leaking gas, shee only does it after Im done riding.I dont loose any power or anything just leaks when Im parked.If anyones had this problem please help. thanks... Quote
Trick2stroke Posted February 28, 2004 Report Posted February 28, 2004 Well I dunno if this is the problem, but when I rejetted my blasters carb, 1 of the hose guides that bolts on between the bowl and the carb was outa wack, and wasn't allowing it to seal correctly, maby you could check that, I dunno if its the prob but check to make sure.. Hope that helps.. Quote
brugal Posted February 28, 2004 Author Report Posted February 28, 2004 Ill check that out tomorrow.But it just started doing it out of the blue I havent rejetted or even touched my carbs.But thanks for the quick responce. Quote
