this could be stupid question to all you experienced banshee owners but i gotta ask a friend asked me where i get my race fuel when i said ive never ran it he said all banshees do and should what my question is will that run to hot for stock pistons? dont wanna burn a hole or damage powerplant because of one guys advice who dont even own a shee also if i should can i still run long n hard on throttle or do i need to break it up? (big dunes and flats)
thx <_<
will there be a noticeable increase in power/performance?
If your compression is around 160 or maybe a little less, you should run the race fuel, because of detonation problems. If you don't have that much compression, then you should just run the premium at the store. There isn't really any benefit if the compression's not there. I would never ever run anything lower than 91 octane. I run 93 from a local store in town, and 91 should be easy enough to find.
Like said before, it's funny how all non-banshee owners have the answers :huh:
Anyway, all octane does is prevent pre-ignition if your compression is high or timing is way advanced. If you're running a stock bike or close to it, you will be wasting your money. Race fuel will most likely not provide any performance in that case.
thx guys shee runs great now so no reason to change what iv been doing although ive only ran 5 tanks since i bought it a month or so go <_< hmm i better check compression anyone know stock comp spec? :huh: that will tell me if bottom end has any mods?
The top end is what determines compression... not the bottom end. Just check the compression and see where your at. My guess is if you ran 5 tanks through and haven't burnt it up.... you most likely fine !!
right on its my first 2 stroke but runs great plugs are a tan to brown in color every time i check them so i should be good besides it runs good enouf to take my brothers yfz 450 with similer mods once we hit 4th gear so i cant complain you know how brothers are :D
