FoxBansheeRacing Posted February 26, 2004 Report Posted February 26, 2004 What should I run with 32mm keihins? My choices are 1/4, 3/16, and 5/16. What would you suggest? Quote
MotulMonsta Posted February 26, 2004 Report Posted February 26, 2004 I run 3/16 with my 28's. It all depends on the carb fuel inlet size. the tank is a 5/16 I belive. the Carbs might be different. Don't be stingy on the fuel line. it will leak if it's the wrong size and no hose claps in the wold will help you. Also make shure you cut the hose so that each carb gets close to equel amouts of fuel so one doesn't run dry. It's real hard if you have a boose bottle as the fuel lines are forced to go eather above or below and you don't get the right angles to permit proper fuel flow. If your carbs have a little nipple like mine do after the slide , just run some vent tube to connect it with the other carb. Quote
