got1banshee Posted February 20, 2004 Report Posted February 20, 2004 I wired up my head lights and only the right one is getting power. I thought I would make a fast temp. fix by running a jumper from one light to the other and then they both wouldn't work unless I unpluged one of them. Hell I am not an electrition I don't have a clue where to start to find out why my left light doesn't get power. THanks Quote
sredish Posted February 20, 2004 Report Posted February 20, 2004 I wired up my head lights and only the right one is getting power. I thought I would make a fast temp. fix by running a jumper from one light to the other and then they both wouldn't work unless I unpluged one of them. Hell I am not an electrition I don't have a clue where to start to find out why my left light doesn't get power.THanks Trace the wires back to the switch. Make sure all the connections are good. Check voltage on both sides where the wires split to seperate lights. How is the ground on the nonworking light, make sure its grounded good. Last, but certainly not least, check the bulb. Quote
