Check this out buddies. I own A 2001 Banshee and a 2001 Blaster. Now the problem isnt with the banshee but instead with the blaster. Well it seems that when i put the bike in gear it does nothing. Wont move. When It first began it smelled bad. Now if I take a look in side the cluthh assembly, what should
I look for that might cause the bike not to move in any gear? Would you guys think it might be something simple as a disk or the whole cluth assembly? Also, does anyone know of a good website where i might find info on how to repair a busted clutch?..... Any help or advice ill do..Thanks
It coud be a number of things. I would start by buying a Clymer manual and go thru the trouble shooting section. It coud be the clutch needs complete replacement {usually just the discs} and you'll be best off with the Clymer manual to walk you thru the repairs.
