prangster Posted February 15, 2004 Report Posted February 15, 2004 Can someone tell me wot the T.O.R.S is and does on the banshee! Quote
sweetshee4312 Posted February 15, 2004 Report Posted February 15, 2004 its someting thats dumb and ive heard of people getting hurt cause they act up, i have a tors removal kit, best thing, get one Quote
blk02banshee Posted February 15, 2004 Report Posted February 15, 2004 The tors does NOT get people hurt. It's on there to keep you from getting hurt. They only "act up" when something is wrong, like a stuck throttle, carb slide, or the carbs are out of synch. Quote
sweetshee4312 Posted February 15, 2004 Report Posted February 15, 2004 well they eventually well fail u, as so ive heard Quote
prangster Posted February 15, 2004 Author Report Posted February 15, 2004 Cheers, so i take it its a kinda electronic throttle shutdown system!! wots the benifit of removing it? Quote
Phast Posted February 15, 2004 Report Posted February 15, 2004 Most of the time when people remove the T.O.R.S. system, its because it failed on them or it just keeps getting in the way when rejetting! There is no benifet when removed.......just more room. If you plan on removeing the T.O.R.S. system you must do it right and TAKE IT ALL and I mean ALL OUT, because if you dont things will start to happen and you wont like it. And the kit you buy make sure its a good one like a toomey or moton pro, ect..... and dont forget the idle kit too..... Quote
fast frankie Posted February 15, 2004 Report Posted February 15, 2004 any body take it off with out buying the kit can you take the plugs off and tie certain wires together. Quote
Phast Posted February 15, 2004 Report Posted February 15, 2004 Sure , just unplug the box under the tank! Quote
fast frankie Posted February 15, 2004 Report Posted February 15, 2004 will I just be able to cut off the plugs Quote
Phast Posted February 15, 2004 Report Posted February 15, 2004 Unplug the brain, brake switch on the handlebars, and the carb tops! Quote
