g-lo Posted February 14, 2004 Report Posted February 14, 2004 what is the biggest carb that you can use and still use the stock rubber boots. i want to keep the airbox on becaues i ride in thru alot of creeks and mud. i am about to to get a +4 crank and want to put a bigger carb. is there kits that i can buy that would let me keep my stock airbox. i was thinking about putting on a keline 30 or 33 not sure witch. thanks for you help Quote
itsaripper Posted February 14, 2004 Report Posted February 14, 2004 The stock boots will only take a 28mm carb. If you want to go bigger UPP makes some aftermarket boot that go over 30mm to 34mm. Also the stock intake will take the 28mm but will have to be changed if you go bigger. Quote
