gbf4ever Posted February 3, 2004 Report Posted February 3, 2004 One of the bolts holding on the rear master cylinder was stripped. I tried using a craftsmen drill out to remove it but the drill out broke off in the bolt. So im tryign to figure out how to remove it. If i cut a slice through the bolt could i use a flathead screwdriver to remove it. give me some ideas. Thanks alot Quote
wheeleymaster99 Posted February 3, 2004 Report Posted February 3, 2004 did the head break off or the threds strpi id the heads still on it cut a slot in it like you said but if the hear broke off you'll halft to drill it out and back it out with a screw driver Quote
gbf4ever Posted February 3, 2004 Author Report Posted February 3, 2004 the heads still on so ill try cutting it and usign a flathead Quote
eehsnab2 Posted February 3, 2004 Report Posted February 3, 2004 When that happens I usually break out the old dremel and make a slice in it just like you said. Quote
