roosthrower Posted January 29, 2004 Report Posted January 29, 2004 my front shocks seem to bottom out alot easier than my step dads 95 shee. the preload is adjusted to the max on mine and same for the 95. Do the j-arms have less travel than the a-arms. Also the shock springs are different. His coil up tightly at the top of his shocks and mine don't. Quote
Holyman Posted January 29, 2004 Report Posted January 29, 2004 your shocks are probably worn out. if all the shocks are original, his are a minimum of 5 years newer than yours. The J and A arms have the same travel since the length is the same. Get some newer used shocks and you should be good to go. Quote
