vmaxup Posted January 25, 2004 Report Posted January 25, 2004 Ok Ive had a problem with the rod and ball welding together, And had as a discusion for Help my clutch for Glamis. The Shee runs great and no problems yet. Iwas reading some other discussions and again someone mentioned the TZ bearing for 40bucks. What is it and were do I get it? I am currently running 2 quarts of oil . No problems yet Quote
fixitrod Posted January 25, 2004 Report Posted January 25, 2004 http://www.grandriverracing.com/bansheetran.html The tz bearing you are refering to usually is a crank bearing. The link I posted above is what you are refering to I think. It's a needle push rod bearing kit. Quote
wesw Posted July 20, 2005 Report Posted July 20, 2005 http://www.wickedatv.com/duportal30/home/c...hannel=Products the part is called banshee clutch pusher 50 bucks works great wes Quote
