rebelbanshee2 Posted January 27, 2004 Report Posted January 27, 2004 i would check the adjustment of the shifter before i replaced it Quote
erbilabuc Posted January 28, 2004 Author Report Posted January 28, 2004 i would check the adjustment of the shifter before i replaced it what should I be looking for? I know about the equal lengths, i ordered a clymer manual but its obviously not here yet. Do you think that the type of oil I use will have anything to do with it? Quote
sheeweet Posted January 28, 2004 Report Posted January 28, 2004 So I guess it wasn't the shift star thingy so cool. But about the washer. I put one about 3/32nd" thick between the shift lever and the stator cover, on the shift shaft. It greatly reduces play in the shift shaft whick led to my mechanism loosing it woith the shift shaft. It will never hapen again. It has happened to lots of peeps here with shee's and that is what they advised me. Quote
erbilabuc Posted January 28, 2004 Author Report Posted January 28, 2004 its fixed and my two problems were 1st- clutch perch adjustment was all the way out so it couldnt open up any more. I had to tighten the tension at the actual clutch. 2nd problem, was that I had a leak at the bottom of my clutch case cover but couldnt tell so i was loosing oil so I had low oil in the clutch. Both problems fixed thank god Quote
. Posted January 28, 2004 Report Posted January 28, 2004 lol, I bet you learned a valuable lesson, adjust your clutch with the adjuster at the clutch perch all the way in. Quote
erbilabuc Posted January 29, 2004 Author Report Posted January 29, 2004 it had me crying all day yesterday cus I just could not figure it out. I thought I was gonna have to buy a new shift shaft Quote
