Wasup guys.
I just rejetted my engine and now my throttle is sticking and won't idle at a low rpms. It sometimes sticks at a higher rpm and I know that's not good. What can I do to fix this? Do I have to buy a new throttle cable? That's what a guy told me at the atv shop so I'm curious to what you guys think.
Thanks as always!
The best way to stop them from sticking is to replace those stock carbs with a set of flat slides or D slides.The stock round slides stick,and they stick worse when you ride in wet conditons,I had the same problem.
If your not going through water or letting it sit in the rain, you may just have a bad cable. I never had a problem with stock carbs unless I was in water. I'd try a new cable or lube it first.
