I don't know what a "sheded key" is but if you are talking about the flywheel key, it would probably be back firing or in some cases, the engine will run in reverse.
The timing would be way off, you would experience backfiring, poor power, ort the engine would not run at all. You should know, you already "sheded" (sheared) one. My guess is it happened again. Please do not post the same shit in several different forums. Also, often times, people cannot reply the second your topic is posted. BE patient. It is a virtue...
