Bigcali Posted November 9, 2020 Report Posted November 9, 2020 Hey I have a 2004 banshee I replaced the clutches in it checked the rod and ball they was totally fine road it up and down the road a couple times it did awesome then I got it out 1 day to ride it and I was letting it warm up and it started making this horrible screeching noise like my clutches was stuck together so I was like wtf killed it popped it in gear pulled the clutch in and rolled it back in fourth and popped the clutch a couple times hoping the clutches would free themselves but they didn’t or that’s what I thought I started it back up still made the horrible ass noise put it down in first and with the clutch pulled it it just try to go and killed it self so I put it back in Neutral and it found a gear in neutral so I was like wtf took the clutch cover off and the clutches was totally fine I do have so wear on the basket but it’s not to bad and the ball and rod was still fine to so any suggestions? Quote
kawa110 Posted November 9, 2020 Report Posted November 9, 2020 Did you soak the plates before install. I had a clutch do same thing. Toasted. is the basket grooved? Time for new maybe. Quote
Bigcali Posted November 10, 2020 Author Report Posted November 10, 2020 Yes I soaked them for about 3 day actually I worked on it some more and I feel like a gear is fucked up in my transmission because I tried the old plates and old springs and adjusted it then tried the new plates with old spring and adjusted that but I also noticed my shifter had play in it through the casings so I stuck a washer behind that to keep it pulled out and it still didn’t fix it idk Quote
