My banshee was running just fine until going through knee high water and the carbs stuck open. I cleaned and synced the carbs and ever since then it starts ok but gradually loses power after 5min of riding. Ive checked the whole wiring harness cleaned and die electric all connectors. Ive replace stator, pickup coil, coil and plug caps, cdi, spark plugs. It has old vforce 3 reeds in it and i can barely see light gap between the reeds and cage. It has good compression also.
The only thing left i can think of is the old reeds are geeting weak but im not sure if itll fix it
