KEVPOPPAPUMP Posted December 13, 2003 Report Posted December 13, 2003 How in the world do you remove the pilot bearing in the top of the case for the clutch arm lever? I have been pounding away with screwdrivers and punches and have only been able to get the bearings out. The outer race is stuck in there and not budging. Should I just go out and get the pilot bearing removal tool that the Clymer's manual says to use or is there any other way? Quote
rebelbanshee2 Posted December 13, 2003 Report Posted December 13, 2003 after pounding on it for a while i gave the case alittle heat and it popped right out. Quote
