alaskabanshee Posted December 13, 2003 Report Posted December 13, 2003 ok i have a 97 shee am puting on a Trinity's 535 Cheetah kit with a 10mm crank v-forc and t-6 pipes and 35mm carbs what type of speed wood i get out of it on a flat run Quote
alaskabanshee Posted December 13, 2003 Author Report Posted December 13, 2003 hay thank you i just wanted to get some of a idea of what it will do and is it worth it to put that muth $$$$$ in to it Quote
00BANSHEE Posted December 13, 2003 Report Posted December 13, 2003 You are wasting your time putting the T6 pipes on that motor unless you plan on just using it to ride around your yard. Get some decent inframe drag pipes so it can breath. Also the reeds will come with the Cheetah kit, and they may have started using something other than V-Force because the reeds have been breaking apart on the larger Cheetah setups. Good luck with your choice. I love mine. Quote
alaskabanshee Posted December 13, 2003 Author Report Posted December 13, 2003 does the kit really kick ass over the others ? am trying to get all the info that i can when i build my shee i want it to rip Quote
raxen Posted December 13, 2003 Report Posted December 13, 2003 Cheeetah is the way to go, nikasil plating inside so you gain about extra 2 HP from beating out some frictional losses. What type of HP range are you looking for out of an engine? Quote
00BANSHEE Posted December 13, 2003 Report Posted December 13, 2003 100++ If setup right it will easily be over 100HP. Quote
alaskabanshee Posted December 13, 2003 Author Report Posted December 13, 2003 thank you for the help am going with the 535 Cheetah and a good set of drag pipes and a 10mm crank thay told me 125+ hp it is going to just rip Quote
raxen Posted December 13, 2003 Report Posted December 13, 2003 It might. You can always go bigger than that. Quote
Hockey390 Posted December 15, 2003 Report Posted December 15, 2003 was just messing around with that link to figure out speed... And at 5k RPMS with 22 inch tires, i will hit 106 MPH in first gear with a 23 tooth front and 10 tooth rear sprockets.. =) If that was true and hyou could do that... WOW.. but ya, sorry I had to share my foolishness with everyone! Quote
erbilabuc Posted December 15, 2003 Report Posted December 15, 2003 was just messing around with that link to figure out speed... And at 5k RPMS with 22 inch tires, i will hit 106 MPH in first gear with a 23 tooth front and 10 tooth rear sprockets.. =)If that was true and hyou could do that... WOW.. but ya, sorry I had to share my foolishness with everyone! cut your case in half to stick the 23 tooth in the front. Doesnt seem that hard now does it? Quote
Hockey390 Posted December 15, 2003 Report Posted December 15, 2003 lets try it... Anyone got a banshee to donate to BansheeHQ Science Foundation?? Quote
alaskabanshee Posted December 17, 2003 Author Report Posted December 17, 2003 ill give my bro's 300 ex eheheh he dose not like my shee too fast the puss Quote
