Sounds like a bogus story. I don't know any carbs to support that mixture.
Ok > if that is not true iam thinking of using alcohol I have some question
1. Do I well face any problems with alcohol
2. Is there some thing i should know about alcohol before using it
Thanx
2. You will need new carbs.
1. A problem faced by many with alcohol is a location to purchase it. Make sure there are some in your area before you convert. I have found a local strip that sells it, they are a good place to start.
converted stock carbs can work with alky,i would only run alky if you are going to be drag racing.you will use 2 or 3 times the amount of alcohol. only run alky if you are proficient with jetting. it is very tempermental to humidity and temp changes in the weather.2 or 3 times the alcohol mean that much premix also.you gotta do your homework.it not as easy as just switching over fuels.
