Seansainsbury Posted November 15, 2019 Report Posted November 15, 2019 Hey guys my headlights and taillights keep blowing. I put a new voltage regulator on and new bulbs and they only lasted a few seconds and blew. I’ve gone through all the testing and the yellow and black wire coming from the Stator puts out about 12 volts when unhooked from the wiring looms and idleing. I checked the resistance and it is showing 0.0 from the yellow to black wire coming from the stator. I know it should be 0.2 or something like that but it’s 0.0. So my question is is the lighting coil bad on the stator? And do I need to change the whole stator? Thanks for any help Quote
97Screamer Posted November 15, 2019 Report Posted November 15, 2019 Oem voltage regulator and lights or you trying to run leds on AC current? Plug your volt meter into the headlight sockets in AC mode and see what you're getting.Sent from my HTC One M9 using Tapatalk Quote
Seansainsbury Posted November 15, 2019 Author Report Posted November 15, 2019 Yes oem regulator and lights. The headlight sockets are showing around 11 volts ac and when I do continuity between black and yellow on the socket it shows 0.0. But if I unplug the black and yellow from the stator there is no continuity. Quote
97Screamer Posted November 15, 2019 Report Posted November 15, 2019 Leave the volt meter in the light socket and rev the bike up. Does it go above 11V? I wouldn't get too caught up in ohms on the lighting circuit, its probably a cheap meter or in too high a range to detect the 0.2ohms. You can also test voltage coming out of stator between the black and yellow wires. Should be ~12-14Vac at idle and 30-40Vac when revving. Quote
Seansainsbury Posted November 15, 2019 Author Report Posted November 15, 2019 It doesn’t go much above 13 out of the stator when revved uo Quote
