4mm cub 421 drag ported by F.A.S.T racing, wiseco true and welded hot rod crank, tz,max load bearing stock ratio straight cuts with 8 plate clutch with dd lock out and cover, v force 3's, chariot head,intakes and stator cover with jds support. 39mm pwk carbs with pj's. shear sb one out each side. chassis is a wheelman chassis single arm hybrid +10 out front marvin shaws all around, +14 metal tech swing arm, torch works radiator, drag tank with pingle. hs customs hood with jds flame grille and stk cut and painted rears. drag cut seat. 40mm gun drilled drag axle, dd 10x2 spindle mounts, 14 stag extreme 73 ro. bike runs consistent 4.0's no bar with 175ibs rider. Located in southeast Michigan 7500.00 obo
E7FDC739-C75C-4CB0-9D2F-39781A7CA688_zps
