dano3 Posted May 15, 2019 Report Posted May 15, 2019 Clearing out some stuff i have laying around and dont need. All prices are OBO. Let me know if you want better pictures. Pwk 33/35 carb bowl modified/welded to clear clutch arm actuator. This will prevent access to mainjet with bowl installed. Got this with a set of carbs but didnt need it with my intakes. Have never checked for leaks but will verify before selling. $20 Clean clutch cover with wear from boot and brake lever. No waterpump-$50. With billet impeller and plastic gear-$75 Welded hotrods 4mm crank. Will require rebuild and new bearings. There is some pitting on the flywheel surface from corrosion between flywheel and crank after lapping but flywheel key never slipped-see pics. $90 Sent from my iPhone using Tapatalk Quote
70duster Posted May 15, 2019 Report Posted May 15, 2019 Ill take the reed cagesSent from my SM-G973U using Tapatalk Quote
70duster Posted May 15, 2019 Report Posted May 15, 2019 And the shift starSent from my SM-G973U using Tapatalk Quote
dano3 Posted May 15, 2019 Author Report Posted May 15, 2019 all PMs replied. Cylinders, shift star, reed cages, impeller, and trans parts sold. Quote
