I want a good power gain like a 421 or 4 mill stroker mainly ride trail or what are some other good power gains ? Cost friendly
I plan on running 98 pump
I have FMF Pipes
236 Feet is my altitude above sea level
What are your current mods?  Can I suggest you port your OEM cylinders (if that’s what you have now).  Setup your carbs and pipes to compliment the porting and your OEM motor will rock out!!
